Evening guys.
I'm running VirtualDJ 8 with my Vestax SPIN midi controller. Generally it works great but the past couple of times i can be mixing away, jog wheels working perfectly fine when all of a sudden, the jog wheels on the Vestax Spin stop controlling the VirtualDJ decks and start scrolling the song list up and down.
To stop it, I typically have to stop VirtualDJ and start again.
Am I accidentally turning on a function or could this be a bug?
Thanks
Thanks
geposted Mon 29 Jun 15 @ 3:32 pm
Please check if you changed something on the default mapping by mistake.
If a vestax custom mapping appears on the controller tab , please try to set it to factory default and try again.
Please also assure that you do not use aV7 Mapping of a previous V7 installation.
geposted Tue 30 Jun 15 @ 6:10 am
Ok i can see there is an issue with the UP/DOWN buttons. We will fix this and let u know about the fix.
EDIT. fix is available in builds ending at .1018 (and higher)
FYI. Both Jogwheels will be set to Browser Scroll mode if any of the UP, DOWN and PFL buttons are pressed (we have not changed this behavior) , but now they will be normally set back to Scratch/Bend mode when these buttons are released.
There was a bug in the UP/DOWN buttons that could leave the Jogwheels to Browser mode even if those were released, but as above, it has been fixed.
geposted Tue 30 Jun 15 @ 7:11 am
I'm using Mac version 2348.1075 and am still having the jog wheel scrolling issue. It comes on out of no where...
geposted Mon 07 Dec 15 @ 1:48 am
Using a Hercules Console 4-Mix
2348 is a very old build. please update to the latest version.
geposted Mon 07 Dec 15 @ 11:44 am
Make sure you are using the default factory mapping files. In case you are using some custom one, see how the UP and DOWN buttons are mapped in the default one.
geposted Mon 07 Dec 15 @ 12:45 pm
