Forum: Wishes and new features
Topic: WISH: better XFade costomization
Hi,
it would be very nice if i can costomize the curve of the Xfader (degressive, Progressive, fix, proportional ) the way i like.
For Example a Setting with a degressive curve within the next 1,5 cm to max. db.
if there is no way to create a grafic costomization what about a scale entry?
The Xfader is 5 cm long (2,5 cm each side)
Each 0,5 cm is one point to difine the curve ( 0 to 9 are possible Values - 0 is equal to 0 db and 9 equal to max db)
The Example (degressive curve within 1,5 cm to max db) setting so takes
L____C ____R
0589999999 L to R
9999999850 R to L
a proportional curve would be
L____C ____R
0123456789 L to R
9876543210 R to L
so each curve can be created on any length of the xfader. If i like to i probably set
L____C ____R
0999999999 L to R
9999999990 R to L
what means that i set the xfader to max. db within the first 0,5 cm
This would be nice because i can adjusst the Xfader exactly to my transformation skills ;-)
Greeetings
Pasknalli
geposted Mon 29 Jun 15 @ 4:14 pm
there is a custom crossfader setting in the advanced options
mines set this way
0=[1,0]/0.25=[0.92,0.45]/0.4=[0.88,0.75]/0.5=[0.82,0.82]/0.6=[0.75,0.88]/0.75=[0.45,0.92]/1=[0,1]
there was some threads on this a while back might just do a search
this one dips the volume in the center
So if its possible to set a degressive curve from 0 db to max db within the first 1,5 cm (each side) what do i have to enter in the custom crossfader setting ?
The number before "=" is the xf travel, the numbers in the "[ ]" are the proportion of the output.
thx, i find a discryption after i use the google-search again (the forum search wont help me out:-( )
And it delivered this
0=[1,0]/0.5=[1,1]/1=[0,1]
Far Left position
Volumes on the far left position. First Value is for the left deck, second value is for the right deck. Usually you WANT this value to be [1,0]
Position of the slider. Here 0.5 is for the middle position of the slider
Volumes on that position (middle position). On this example both decks have full volume. You could write [0.5,0.5] or [0.75,0.75] e.t.c.
Since this is the middle position, on most cases you want both values to be the same
Far right position
Volume on the far right position.
greeetings
Pasknalli
