Discussion about TheLightingController8
geposted Mon 29 Jun 15 @ 7:02 pm
SBDJ wrote :
This add on looks interesting. I have all chauvet lighting and the obey 40 controller. What do I need to make this work? Where should I save the program? Thanks DJ Point5Discussion about TheLightingController8
geposted Wed 01 Jul 15 @ 8:30 pm
You'd need to be using their DMX application (showxpress) with their DMX dongle, which is what this integrates with.
geposted Thu 02 Jul 15 @ 8:31 am
Hello scripting V7 are still valid for use with the V8?
Quand je fais clic droit sur le CUE
TYPE : ACTION
CUE: Cue 9
MACRO ACTION : DMX|PRESS|VIOLET
Is that what I should do or what is false?
I try to set the IP address the 7348 port and password not under TheLightingController DMX Applications I took in preference SWEETLIGHT and no CUE s not activate?
Why is he loaded something else or turn something else?
Bravo and thank you for t be addressed this V8 and thank you for your help.
Without dong box software that does not work?
I did some tests without the case.
Francky108.
TYPE : ACTION
CUE: Cue 9
Francky108.
geposted Thu 02 Jul 15 @ 4:53 pm
https://virtualdj.com/forums/201982/VirtualDJ_Plugins/TheLightingController_(inc_ShowXPress__SweetLight_etc).html
TYPE : ACTION
CUE: Cue 9
MACRO ACTION : set dmx_cue 9
TYPE : ACTION
CUE: Cue 9
geposted Fri 03 Jul 15 @ 9:07 am
Hi Scott, I am doing some testing and for some reason it does not seem to pass the CBG to my other laptop. Did that feature carry over to the new plugin?
geposted Fri 03 Jul 15 @ 1:51 pm
Bonjour à tous.
SBDJ j ai souvent râle et mon impatiente a été lourde et longue à porter.
Mais vraiment tu es un super geni
Un mec super cool
Et vraiment tu as réalisé un de mes rêves.
Ta nouvelle appli est encore plus simple et j adore.
Very you are the best et very good satisfaction.
Un mec super cool
geposted Fri 03 Jul 15 @ 3:02 pm
Yes, its working for me here.
geposted Sat 04 Jul 15 @ 3:47 am
Thanks, got it sorted. I guess I set an external app control password. The new Show Express 7.1.62 does not seem to show that setting (not same as admin password). I went back to my old VDJ 7 plugin and saw what that was..
geposted Sat 04 Jul 15 @ 8:12 am
You can still get to that setting, its just in a different place. It's accessed from a different settings button. I'm not in front of my computer now but will find it later.
geposted Sun 05 Jul 15 @ 5:13 am
Bravo Tiger ;)
geposted Mon 06 Jul 15 @ 7:36 pm
Nice to see you post Mr P :)
geposted Wed 08 Jul 15 @ 5:37 pm
Can someone please explain how this plugin works step by step?
geposted Tue 21 Jul 15 @ 2:15 pm
Scott,
With this plugin, does it allow you to bypass the lack of Sweetlight access to Macs Sound Card? Can I send from one Mac to another and keep the beat sycning for lighting?
geposted Sun 06 Sep 15 @ 1:52 pm
Yes :)
geposted Sun 06 Sep 15 @ 11:07 pm
Is there any documentation that explains how to use this add on with Chauvet Show Express?
EDIT: Just saw the link above that explains a lot.
geposted Mon 01 Feb 16 @ 7:23 pm
Since the last update I got problem with the Auto BPM. It does not work at all and the reaction on cue´s to change a Macro (or equal) in Showxpress is very slow.
Is this known problem or is it just me?
geposted Sat 11 Jun 16 @ 2:51 pm
I have a pro licence but its not letting me download this why? I have 8.2
geposted Thu 14 Jul 16 @ 10:55 pm
I am getting an installation error when trying to install this plugin. Can someone assist with this please?
geposted Tue 27 Sep 16 @ 11:07 am
Okay, I have vdj 8 infinity and would love to have a dmx setup that would work with vdj 8.... what would i need, bare necessity, to get started?
geposted Sun 05 Feb 17 @ 7:24 pm
