Topic: Remote device settings window pops up
As per title, if I go to config - options, do not enter anything in the searchbox and hit enter the IP config window for remote devices pops up.
Once that happend, I can change to another config window, hit enter, and the window pops up again.
Is this a bug or by design?
EDIT:
Okay, it does not always happen.
Steps to reproduce:
- start up vdj
- go to config - options, click into the searchbox, hit enter, nothing happens
- now open the remote options
- click on the + button in the bottom left corner
- close this window with cancel
- go to options tab again, click on searchbox, type something in - or don't do so - doesn't matter
- hit Enter
- IP window appears
It seams, that the + button doesn't loose his focus when the options tab is changed. And hitting enter will always trigger the button.
geposted Tue 07 Jul 15 @ 5:40 am
