I version 7, you could load a track into your sidelist. then when you loaded it into a deck from the sidelist, it would be removed from the sidelist.
It appears in version 8, that when you load the track form the sidelist, it still stays there until you delete it.
Is there an auto function/setting in version 8 that allows this to occur?
geposted Sat 11 Jul 15 @ 1:15 am
There is a setting for this (set to No by default) removePlayedfromSidelist. Set it to Yes
geposted Sat 11 Jul 15 @ 6:40 am
How does this work when you add the track to a deck (not playing it) then you change your mind and add something else, now the first track is shown twice.
How do you get rid of the second copy showing?
geposted Wed 15 Jul 15 @ 11:08 pm
search for SIDELIST and set "NO" to saved unplayed etc...
it's just below the one you just did above "removePlayedfromSidelist"
geposted Thu 16 Jul 15 @ 9:46 pm
