Hi folks. I have what I hope is a simple question. When using Automix without the Shuffle option it is always obvious what song will play next. But when using the Shuffle option how do you tell what song is queued up next? I have tried putting the cursor over the song on the play bar (wave image) and that doesn't do it. Right clicking on that bar doesn't do it either. How do I identify what song is queued next?
Thanks,
Rob
Thanks,
Rob
geposted Mon 13 Jul 15 @ 1:48 pm
Place your mouse cursor over the second wave form in the player and a tooltip will pop up with the song name.
Make sure tooltips are enabled in options.
geposted Mon 13 Jul 15 @ 2:16 pm
That's what I thought but it's not working. What could I have set wrong? It's a windows 8.1 system!
Never mind: The 'TOOLTIP' option was set to "NO". Thanks for showing me what to look for by saying 'tool tip' :-).
Rob
Rob
geposted Mon 13 Jul 15 @ 2:22 pm
I guess if it can be seen as a tooltip, then in theory you could have "next song" show on the skin somewhere (i.e. below the artist name) with a spot of XML modification...
geposted Tue 14 Jul 15 @ 9:13 am
