Forum: Old versions
Topic: No sound from Denon HC4500
I tried to set up my Denon HC4500 with Virtual DJ Pro 8. However while Virual DJ found the HC4500 and worked with the HC4500, the one thing that did not work was the sound. There was no signal going to the mixer which is a Denon X500.
Any idea where I might be going wrong?
geposted Mon 13 Jul 15 @ 3:28 pm
....and your sound configuration is?
I assume you've installed the Denon ASIO driver.
Thanks for that Grooving, no I haven't. Silly me I will try that and see what happens.
Just a quick update, yes that was the problem. Once drivers installed all working.
