Topic: Song plays backwards on one deck
I have just updated to V8 and deck A seems to only play backwards but deck B is fine..
geposted Tue 14 Jul 15 @ 4:41 pm
Please do a rightclick on the Play button of deck A and try again.
Right-click will not help.
Press the Q key on your keyboard and try again. Once this is fixed, goto CONTROLLERS tab, and choose the "Default" keyboard mapping instead of the "Optional"
This is still not helping, I have deck be playing the song backwards when I right click on the play button it will play forward but the minute I let it go it goes back to backwards
Problem:
When a song is playing on a deck, pressing the right mouse button does NOT pause, it will instead REVERSE the music.
Cause: The CONTROLLER SKIN being used has a button mapped to REVERSE.
Solution: Open the XML file, search for the word, 'reverse', and delete text referring to the button and the unwanted action.
For example with MixTrack Pro, right clicking on the play/pause button when a song is playing, will result in the the song being TOGGLED to play in reverse/ forward. By toggled, I mean it has 2 possible actions when you right click on it; reverse or forward.
If you want to keep the reverse/forward button for future use then take no further action - just be careful how you click.
For the temporary fix - to set things right, start the current song on the deck by clicking on the play/pause button using the LEFT mouse button, and while the song is playing, RIGHT click on the play/pause button. This will toggle forward play.
To PERMANENTLY disable the reverse/forward on the play button, open the controller skin file that you use, search for the word 'reverse' and remove the action associated with it.
MixTrackPro skin example:
<button action="deck 1 loaded ? deck 1 play ? on & deck 1 play_pause : on blink & deck 1 play_pause : off & deck 1 play_pause" rightclick="deck 1 reverse">
Change it to:
<button action="deck 1 loaded ? deck 1 play ? on & deck 1 play_pause : on blink & deck 1 play_pause : off & deck 1 play_pause">
Search again for the word reverse, and you will see it for deck 2 as well. Do the same - delete the rightclick action.
Or, just to simplify, restart the program. Worked for me. Just make sure to reselect your custom mapping when you restart.
hi
how do you stop the left wheel on virtual dj going backwards please
thanks
set up a custom button with this script on it
reverse
if the jog is going backwards and this button isn't lit up then you are in dump mode.... or you're at pitch -200% [not likely]
