Forum: Old versions
Topic: Mic Help?
Hi Guys, I am using VDJ v8. I am wanting to run a live! show. Is there a keyboard function for dipping the music while you talk? I have looked and can't see anything to help. I have to use my mouse to drop the volume slider to talk. Any help on this would be just great?
Thanks in advance
Mike
geposted Wed 22 Jul 15 @ 7:00 am
You can try this:
deck 1 level 50% while_pressed & deck 2 level 50% while_pressed
Search the forum for 'ducking'. There are several posts which go into more detail about how it can be done.
Hi, sorry but how do i set the deck audio level to 50%? is it in mapping I think? and how then do I drop the music for voice overs?
Thanks
You need to assign the script PachN posted to a custom button.
