Topic: Video Edits Opening
Hi all in VDJ Land can anyone help please. when I first load a video by dragging on to the decks its okay but if I drag another over it to load, the video edit window opens, it doesn't open if I double click to load or right click & load on deck 1 or 2 I am using VDJ latest build. Any ideas thanks
geposted Thu 23 Jul 15 @ 6:09 am
Which skin are you using?
I was using Focus Adion but now I've been told its not compatible with latest build so had to change it at least for now. Thanks for your reply.
I'm having the same problems with the VDJ 8 skin I use which was custom made by Scott Bye... The only way to get rid of this problem is to use the standard VDJ 8 skin which I don't like using for my video mixing :(
Why has this broken?
It seems that you have to drop the video file on the area above the video box area where the song title info is for the video to load without issue... If you drop the video on the VDJ video window box, the video edit pop up box appaers.
The new beta build 2369 offers the ability to skinners to choose (or offer both) what needs to have priority (loading tracks or video linking).
The Focus skin offers a fix already. https://virtualdj.com/forums/193457/VirtualDJ_Skins/_NEW_v8__Focus.html
If you have any troubles with other skins, i would suggest to post in the Skins forum or contact the author.
