Forum: Wishes and new features
Topic: Beat Grid on Variable BPM tracks
I have some tracks that they have variable BPMs. That means they can start i.e. at 90BPMs and then on one position they go to 130BPMs and then back to 90BPMs.
With the BPM Editor i can adjust this difference but the Beat Grid stays the same from the beggining. The problem is that i must readjust the Beat Grid to reset on the start of the new BPMs (1st beat) because the BeatGrid doesn't always stay the same on the whole track... It means the new BPM comes to the 2nd beat of the BeatGrid and not the 1st... (I know it's complicated to explain...)
I tried to put a new Beat Anchor with the POI Editor but it didn't help...
Do I miss something or there is currently no way to do that?
geposted Fri 24 Jul 15 @ 2:29 pm
Additional BeatGrid Anchors change the grids just fine here.
Its the BPM Editor you should use, not the POI Editor. There is button "Variable BPM" there.
Here is just a rough example (the BPM is not changed in this track, but added a 2nd Beatgrid Anchor just to show you how the grids change)
In case i miss-understood, please provide an example with screenshots.
