Forum: Old versions
Topic: How do I revert to default settings?
How do I reset my settings in VDJ8 to the default settings?
geposted Sun 26 Jul 15 @ 4:42 am
Use the Restore Factory Default button (config/options).
Or close VDJ8 and rename your settings.xml file (Within Documents\VirtualDJ) to something else (ie. settings.xml.backup and re-open.)
