Hiya I just got a Numark mixtec pro Dj controller.. I have it all set up an working good apart from staic output .. I'm running on vd7 an an my laptop is more than capable of running it.. But when I pulg into a another laptop it works fine.. PLEASE HELP thanks for your help
geposted Sun 26 Jul 15 @ 12:56 pm
Does this static noise gets away if the laptop is on just the battery ?
Read here.. https://virtualdj.com/wiki/Ground%20Loop.html
geposted Sun 26 Jul 15 @ 1:31 pm
Yea tried that too an still same problem even with the with ground loop isolater..
geposted Sun 26 Jul 15 @ 2:21 pm
You seem to have solved the problem yourself. If it works fine on the second laptop, then the problem is......the first laptop.
What is the difference between the two laptops?
geposted Sun 26 Jul 15 @ 2:27 pm
Mine is AMD processor, 4GB Ram and standard hard drive. His is Intel Processor, 6GB RAM and Solid State Hard drive
geposted Sun 26 Jul 15 @ 2:43 pm
