Introduced in Beta 2352:
-Auto-generate video edit by dropping video file on video preview of audio file
When using a skin like DJDads "Focus" skin, with full deck sized video previews its impossible now to continue to load new tracks to the decks without a video edit being created.
Would it be possible, Devs, to allow us to disable this feature if its not needed, or maybe give us a work around without having to "just switch to a different skin" please??
DJDad is aware of the issue here and has already tried looking into a work around from the skinner point of view but i feel it's down to the Devs with this.
I'm too used to being able to drag chosen tracks to deck, a quick work around could be to use a custom button but its not an ideal solution :(
geposted Sun 26 Jul 15 @ 9:24 pm
Fixed in Beta build 2369
Needs new update of skin v2.1 http://www.virtualdj.com/forums/193457/VirtualDJ_Skins/_NEW_v8__Focus.html
geposted Sun 26 Jul 15 @ 11:44 pm
