When keylock is on and the very first time the pitchslider is touched, a small glitch in audio is heard.
The track has to be restarted, and the same thing occour.
geposted Mon 27 Jul 15 @ 1:23 pm
By Key Lock you mean Master Tempo?
If so, I can't reproduce that.
geposted Tue 28 Jul 15 @ 3:25 am
I can reproduce on several machines.
Load a track with a silent intro and you will hear it.
geposted Tue 28 Jul 15 @ 3:45 am
Are you using a controller?
I just tested with the mouse.
EDIT: Okay, you are right. I confirm that.
geposted Tue 28 Jul 15 @ 3:46 am
I have noticed the same thing. What I usually do is load two different tracks onto the two decks, play them with volume faders down, push both decks pitch faders up and down a couple of times returning them to zero. Then I eject both decks and I'm ready for my live performance. I should not need to do this but when I do I don't get the little "pop" for the whole session. Following to see if it is resolved. Thanks.
geposted Tue 28 Jul 15 @ 8:31 am
