Hi sorry if this has been answered before - I have had a look using the search bar but couldn't find the answer.
I have just started using VDJ and am trying to find out how to assign different samples to the F buttons - or my DDJ-SZ pads.
I can't find the option on the software to change the sample - from horn to my own sample for instance.
Is there anywhere in the interface of the program to do that?
Thanks.
Also the links to download the user manuals are not working for version 8 of VDJ.
Thanks.
geposted Sat 08 Aug 15 @ 2:43 pm
It's ok - I found a video tutorial on youtube, so this thread can be deleted now.
Cheers anyway, ps can an admin fix the download link so the user manuals can be downloaded for VDJ 8? thanks.
geposted Sat 08 Aug 15 @ 3:40 pm
We ll fix the links for the manuals. Thanks for reporting.
geposted Sat 08 Aug 15 @ 3:44 pm
Thanks for fixing the download links, I have downloaded the guides now - cheers.
geposted Sun 09 Aug 15 @ 8:56 pm
