Forum: Old versions
Topic: VDJ 8 Build 2378 Failing to install
Hey All,
Never ever had this problem.
Was previously on 2362 and upgraded to 2369.1049 (no problems)
Got next upgrade request (2378) immediatly after previous update and now get a failed to install prompt.
Will do full re-install now to see if that get around it but thought i'd highlight this!
Any ideas on the cause?
(Just backing up all my settings)
geposted Tue 11 Aug 15 @ 11:07 pm
"Yes" doesnt help ?
If not , VirtualDj stores the temporary download in /Documents/VirtualDJ/cache folder. Delete that file and launch VirtualDJ again.
No "Yes" didn't work.
However, tried uninstalling and it failed due to an instance running!
For some reason, VDJ8 didn't close down and the process was still running, although managed to open and close 2369 multiple times whilst getting the update error.
Anyway's cancelled the uninstall, killed the process (Task Manager) and launched VDJ, accepted the update and all went through okay!
Cheers DJDad for your very fast reponse
