Forum: Old versions
Topic: Adding iTunes Directory in VDJ 8
Hi All,
I trust that you are well.
Since updating to VDJ Pro 8, ive noticed that the iTunes extension that i had in the main memory bar in the left hand side has gone.
This was so handy as i could access all my iTunes playlists etc which had the latest tracks etc and simply drag and drop files into the VDJ decks
Now, here's the tricky part.
iTunes is not stored anymore in the usual "Music" folder on my PC.
Instead the itunes library file and all the music/media files reside on an external HD which is plugged into my PC. (For size reasons etc)
Is there any easy way i can get iTunes to show in VDJ 8 and see all my playlists etc for ease of accessing files?
Appreciate your help folks on a step by step guide to do this with as little pain as possible :-)
Thank you so much
DJ Simon Murray.
geposted Wed 12 Aug 15 @ 8:36 pm
