Forum: VirtualDJ Skins
Topic: BUG in Sampler of DjDad Skin MultiFx
Choose any sample you want (lets say the AudioFx)
Now both deck have the AIR HORN
If you change deck 1 to something else like explosion it will play but the other side still says AIRHORN but plays the explosion.
It does not matter which side you choose as long as the AIR HORN is first showing, in either side, it will play the wrong sample.
Also don't matter what bank of sampler you choose. As long as the first on the list is shown on either side, it will play what ever the other side you selected but the display in wrong.
If you select a different sample besides AIR HORN from my first sample, then everything works correctly.
here is a video clip in action.
http://1drv.ms/1J2BKAt
geposted Thu 13 Aug 15 @ 5:36 pm
you are using a version 7 skin on vdj8? certain things wont work..unless the Author updates the skin...
downloaded the skin from the V8 section.
It's not a bug. It's just that the way the sampler works in VDJ 8 is different, and the code in the skin has not been updated to work the "VDJ8 way".
MultiFX skin will have an update, but cant tell when it will be available. Indeed the Sampler works in a different way in version 8
