Build 2398 high memory usage, after 40 minutes VirtualDJ 8 Crash!!!
geposted Thu 13 Aug 15 @ 6:35 pm
Anything specific you did?
geposted Thu 13 Aug 15 @ 7:46 pm
my setup is:
4 Decks con DJM850 and the ASIO of the DJM850
and the same thing happened last Saturday with the previous update
today only create a Automix and wait until Crash, and happened again After 40 minutes.
geposted Thu 13 Aug 15 @ 7:56 pm
since it happens the same time (after 40 mins), any chance the same track was playing at that time when the crash occurred ?
Do you play audio or video files ? any specific file type ?
Btw, what exactly do you mean by crash ? windows crash (application stopped working) or VirtualDJ reopened automatically ?
geposted Thu 13 Aug 15 @ 9:25 pm
sorry for my English
time is approximate, and perform 2 times the test with same result.
It does nothing special, I do not use video effects, I do not use audio effects
MIXED only with diferetes audio and video tracks.
application stopped working, and Windows sends error message "Application not responding"
geposted Fri 14 Aug 15 @ 1:04 am
Hi
the GWX "Obtener Windows 10" is the problem
I have Windows 7
Uninstall "Actualizar para Microsoft Windows (KB3035583)" and VirtualDJ 8 It works smoothly.
I do not know the cause.
I have Windows 7
geposted Mon 17 Aug 15 @ 7:55 pm
