I understand mapping keys to buttons and virtual dj but how do you map them to vst and buttons on the vst.. example a vst keyboard piano... to midi controller.
geposted Sun 16 Aug 15 @ 4:50 am
i been wanting this but by what I hear...vdj wont reroute midi data for additional devices (plugins) to their own channel/ID? but then why is my native instrument controller able to controll its plugin?
geposted Tue 18 Aug 15 @ 9:21 pm
It is possible as I have done it in 7 but since 8 things have changed as example the dials in effects can be moved and thus changing the vst dials too.. now , I have to use 4 decks load the vst to deck three and leave it on and then second screen the vst picture so I can see it and know what im doing . Im mapping a new axiom pro keyboard.. I also have the apc 80 working with my ttx usb into a ddj t1. lots of control but I need to know how to better map the vst buttons.. the code is different and you cant just select the button on the vst then press the piano key.
geposted Thu 20 Aug 15 @ 9:58 pm
