Hello (Google translation) Problem with VDJ8 B2378 video if an external hard drive Virtual DJ creates a directory inside it creates a data at an upcoming opening VDJ8 any video title appears in the browser, you must delete the directory VDJ the external drive.
geposted Sun 16 Aug 15 @ 5:13 pm
I'm not sure if I understand you.
But yes, VDJ will create a directory on your external harddrive. That is the normal behaviour and you should NOT delete this folder.
It contains you database.xml file for the external drive.
If you mean, that everytime you drag a video file to a deck and VDJ creates a new video edit file, that is also a normal behaviour and a new feature.
If it is none of the above, please try to describe your problem again.
geposted Mon 17 Aug 15 @ 8:45 am
Hello
Here is the problem :
geposted Mon 17 Aug 15 @ 1:27 pm
geposted Mon 17 Aug 15 @ 2:04 pm
Intelligence thank you, it works.
Another question: on my computer scan is done only on one line and apparenment possible on three lines. What to do?
and thank you for the speed of your response.
geposted Mon 17 Aug 15 @ 2:18 pm
VDJ could only scan 1 title at a time.
It is not possible to scan more than 1 title at once.
geposted Mon 17 Aug 15 @ 2:58 pm
Yet on my desktop that I use to prepare my evening it works on three lines.
geposted Mon 17 Aug 15 @ 3:17 pm
Ok, I can see that there are 3 progressbars indicating the scan.
But either this is a new feature, or I don't know what is happening here.
Maybe a skin issue?
I really don't know :-/
Maybe a skin issue?
geposted Mon 17 Aug 15 @ 3:31 pm
New builds (2389+) can do multithreaded scanning where possible.
geposted Mon 17 Aug 15 @ 3:36 pm
Okay, that explains it.
But that wasn't mentioned in the changelogs and OP was talking about b2378... at least, that is what the thread title says.
@OP
I don't see a problem here.
All 3 tracks in the browser are mentioned at the info line too.
@OP
geposted Mon 17 Aug 15 @ 3:48 pm
OK SBDJ - on my desktop it works on three but on the animation only one, yet I am with V8.0.0 on both b2412.
what to do to make it work on both?
geposted Mon 17 Aug 15 @ 3:51 pm
@OP
@OP
Yes, but on one computer while on the second there is only one line at a time.
geposted Mon 17 Aug 15 @ 4:19 pm
Maybe your other pc is not a multicore cpu?
geposted Mon 17 Aug 15 @ 6:44 pm
multi scan requires quad core cpu
geposted Mon 17 Aug 15 @ 6:53 pm
