Hello I have vdj8. previously i had vdj le an i upgrade to 8. when i did every time i record a set of mixing an i go to retrieve the file to listen it comes up as a playlist in my finder, a list of the songs i mixed but not mixed just all together all separate. can any one please assit? Thanks!
geposted Wed 19 Aug 15 @ 1:15 am
you should have a .flac or .mp3 somewhere
check recording tab for the location.
geposted Sun 23 Aug 15 @ 4:56 pm
thanks , i had to record in wav instead of mp3,why i don't know but thats the only way i could on my macbook.
geposted Fri 04 Sep 15 @ 12:11 am
I don't know.... maybe you are missing the LAME encoder?
http://lame.sourceforge.net/
geposted Fri 04 Sep 15 @ 9:35 am
Whenever I try to add a song to mix it it says error and won't let me do anything.
geposted Tue 08 Dec 15 @ 6:58 am
