Is there a way to let vdj remember to stay on 3 effects instead of just 1?
I find it annoying that i need to set this every time i startup vdj.
Thanks!
Thanks!
geposted Wed 19 Aug 15 @ 4:58 pm
Are you taking about the skin or a controller issue?
*just tried the internal skin and that sticks, so it must be a controller* (is it?)
what are you using for midi to VdJ?
geposted Wed 19 Aug 15 @ 9:29 pm
When you boot up Virtual dj its always set on just 1 Effect,i can set it to 3 effects with my controller or with mouse but i would like VDJ to remember to stay on 3 effects when i boot up the program.
Im using a Denon DJ MC6000MK2
geposted Fri 21 Aug 15 @ 11:58 pm
you're really not helping me here, this is a skin issue is it? what skin do you use?
geposted Sat 22 Aug 15 @ 8:26 am
You need to add the following script to the ONINIT key of your keyboard or controller mapping...
set '$fx1multi' 1 & set '$fx2multi' 1
geposted Mon 24 Aug 15 @ 11:00 pm
Cant find anything called ONINIT on the keyboard or controller mapping.
But if i need to change a button it means i still need to press it before it changes into 3 effects?
i would like VDJ to do this by itself without pressing a button.
Thanks for the help so far everyone.
geposted Sat 29 Aug 15 @ 4:38 pm
That's what ONINIT does. It's short for "on initializing" - in other words "when started". You can add it to your controller mapping, so that when VDJ starts up (and that controller is connected) the script will run. Alternatively you can add it to the XML of a skin, so that when the skin loads it runs the script.
geposted Sat 29 Aug 15 @ 7:13 pm
Step 1.
Once keyboard is selected (and the mapping file you are using - if the default is not the one), scroll down to the bottom and add the ONINIT key ..
Step 2.
Write in the Action box the script i gave you in my previous post.
geposted Sun 30 Aug 15 @ 5:33 am
Thanks a lot Djdad
geposted Sun 06 Sep 15 @ 11:28 pm
Does anyone know how to set the master effect to 'on' as well?
geposted Sat 31 Oct 15 @ 7:28 pm
deck master effect_active
or
deck master effect_active "FXName"
or
geposted Sun 01 Nov 15 @ 6:02 pm
