Topic: build 2412 crashes constantly
same issue on both my laptops an asus and a HP. playing a karaoke track and crashes several times.
geposted Fri 21 Aug 15 @ 3:04 am
almost happens right at the end of a song for some reason
After reverting to the last public built , the problem has gone away. There is definitely a bug in the latest build. I am able to replicate the results in two different machines with two different video cards with two different operating systems and have the exact same results. Crash
So far the problem has only surfaced while playing karaoke tracks cd+g. Most times the crash happens near the end of the song. at that point it crashes, crashes instantly again and then vdj reloads
if it is always happening with a specific file maybe its bad file?
not seen anyone else reporting this the build is working fine here
Do you use the option "videoUseDXVA" in VirtualDJ b1412?
No, it happens on many different karaoke tracks. same results on 2 different laptops. everything plays fine in all previous builds. Reverted to 2378 and all is working perfectly again.
NO
actually, i just rechecked and its set to YES in the build i'm using now (2378)
