Forum: VirtualDJ Skins
Topic: VU Meter
Trying to get the controller master VU to match on screen VU... but the visual on screen is generally always lower than controller. my guess is that I have multiply the param... but then it still will be off in other circumstances. perhaps I'm not using the right command?
<visual source="get_vu_meter_left & param_multiply 175%" type="linear" orientation="vertical" direction="up">
geposted Fri 21 Aug 15 @ 6:07 am
If the Master VU on your controller is hardware operated (which I believe it is) you're never gonna make the 2 vu-meters match.
The controller's VU-meter uses different scale than software and since the scales are not linear but logarithmic, you can't make them match by multiplying/dividing the master VU values.
Phantom: this is what I currently using and works for only the deck 1-4 meters:
---VU METER DECK 1---
<group name="VU">
(Background)
<button class="LedBG2">
<pos x="+793" y="+436"/>
</button>
-LED #1
<visual class="VU-DarkRed" chan="1" source="deck left get_level_left & param_bigger 4.5% ? param_smaller 13.5% ? on : on : off">
<pos x="+798" y="+620"/>
</visual>
<visual class="VU-DarkRed" chan="2" source="deck left get_level_right & param_bigger 4.5% ? param_smaller 13.5% ? on : on : off">
<pos x="+798+9" y="+620"/>
</visual>
-LED #2
<visual class="VU-DarkRed" chan="1" source="deck left get_level_left & param_bigger 13.51% ? param_smaller 22.5% ? on : on : off">
<pos x="+798" y="+602"/>
</visual>
<visual class="VU-DarkRed" chan="2" source="deck left get_level_right & param_bigger 13.51% ? param_smaller 22.5% ? on : on : off">
<pos x="+798+9" y="+602"/>
</visual>
-LED #3
<visual class="VU-DarkRed" chan="1" source="deck left get_level_left & param_bigger 22.51% ? param_smaller 31.9% ? on : on : off">
<pos x="+798" y="+584"/>
</visual>
<visual class="VU-DarkRed" chan="2" source="deck left get_level_right & param_bigger 22.51% ? param_smaller 31.9% ? on : on : off">
<pos x="+798+9" y="+584"/>
</visual>
-LED #4
<visual class="VU-DarkRed" chan="1" source="deck left get_level_left & param_bigger 32% ? param_smaller 39.9% ? on : on : off">
<pos x="+798" y="+566"/>
</visual>
<visual class="VU-DarkRed" chan="2" source="deck left get_level_right & param_bigger 32% ? param_smaller 39.9% ? on : on : off">
<pos x="+798+9" y="+566"/>
</visual>
-LED #5
<visual class="VU-DarkRed" chan="1" source="deck left get_level_left & param_bigger 40% ? param_smaller 49.9% ? on : on : off">
<pos x="+798" y="+548"/>
</visual>
<visual class="VU-DarkRed" chan="2" source="deck left get_level_right & param_bigger 40% ? param_smaller 49.9% ? on: on : off">
<pos x="+798+9" y="+548"/>
</visual>
-LED #6
<visual class="VU-DarkRed" chan="1" source="deck left get_level_left & param_bigger 50% ? param_smaller 58.9% ? on : on : off">
<pos x="+798" y="+530"/>
</visual>
<visual class="VU-DarkRed" chan="2" source="deck left get_level_right & param_bigger 50% ? param_smaller 58.9% ? on : on : off">
<pos x="+798+9" y="+530"/>
</visual>
-LED #7
<visual class="VU-DarkRed" chan="1" source="deck left get_level_left & param_bigger 59% ? param_smaller 67.9% ? on : on : off">
<pos x="+798" y="+512"/>
</visual>
<visual class="VU-DarkRed" chan="2" source="deck left get_level_right & param_bigger 59% ? param_smaller 67.9% ? on : on : off">
<pos x="+798+9" y="+512"/>
</visual>
-LED #8
<visual class="VU-DarkRed" chan="1" source="deck left get_level_left & param_bigger 68% ? param_smaller 76.9% ? on : on : off">
<pos x="+798" y="+494"/>
</visual>
<visual class="VU-DarkRed" chan="2" source="deck left get_level_right & param_bigger 68% ? param_smaller 76.9% ? on : on : off">
<pos x="+798+9" y="+494"/>
</visual>
-LED #9
<visual class="VU-DarkRed" chan="1" source="deck left get_level_left & param_bigger 77% ? param_smaller 85.9% ? on : on : off">
<pos x="+798" y="+476"/>
</visual>
<visual class="VU-DarkRed" chan="2" source="deck left get_level_right & param_bigger 77% ? param_smaller 85.9% ? on : on : off">
<pos x="+798+9" y="+476"/>
</visual>
-LED #10
<visual class="VU-DarkGray" chan="1" source="deck left get_level_left & param_bigger 86% ? param_smaller 95.448% ? on : on : off">
<pos x="+798" y="+458"/>
</visual>
<visual class="VU-DarkGray" chan="2" source="deck left get_level_right & param_bigger 86% ? param_smaller 95.448% ? on : on : off">
<pos x="+798+9" y="+458"/>
</visual>
-LED #11
<visual class="VU-DarkGray" chan="1" source="deck left get_level_left & param_bigger 95.449% ? param_smaller 100% ? on : on : off">
<pos x="+798" y="+440"/>
</visual>
<visual class="VU-DarkGray" chan="2" source="deck left get_level_right & param_bigger 95.449% ? param_smaller 100% ? on : on : off">
<pos x="+798+9" y="+440"/>
</visual>
</group>
By using individual LEDs, deck meters aligns PERFECTLY from controller to screen.
It's just the master VU Meter I'm having problems with. I think it can be done with the same as above, but I think I'm missing something.
