Virtual dj 7 . I have effect ( in between a flanger and a phaser ) that is on constantly . The EFFECT light is off . But the parameter knobs alter the ghost effect . It's every song . Both decks .
I've restarted the computer multiple times . This program has worked fine for years . Now I can't stop the music from " ringing "
geposted Tue 25 Aug 15 @ 2:26 am
Or just turn off the sound to the effect ... That would work as well
geposted Tue 25 Aug 15 @ 2:34 am
Most likely you have a loop feedback and not an effect turned on.
Check your settings and if needed tell us what soundcard/controller you use and show us a screenshot of your sound configuration
geposted Tue 25 Aug 15 @ 10:24 am
