Can't seem to get my cue point to save or load in VDJ 8. In VDJ 7, I would set a cue point and it would always load at that point. It doesn't do that in 8 and I'm not sure how to get it to do that. Can anyone help? I have tons of songs that need to skip intros and such and I don't want to remember this every time I load the song.
geposted Wed 26 Aug 15 @ 5:22 am
In VirtualDj 8 the "CUE" button does NOT set a permanent cue point. It rather saves a memory point that's lost once the program restarts.
If you need to set permanent cue points you need to use your controller's "Hot Cue" buttons (or the buttons on skin)
These points are saved permanently. Also you can change the "autoCue" option to "cue" so that every time you load a song it loads from hot-cue 1 (if it exists)
geposted Wed 26 Aug 15 @ 7:32 am
Thanks... I don't think I would have found that without help.
geposted Sat 29 Aug 15 @ 2:25 am
