Just bought a Gemini CNTRL-7 for my Mac Book Pro it has OS X Yosemite 10.10.5, the virtual dj package that came with has a version thats too new for my mac. The second version that is compatible, but its come up with the invalid skin error. Not sure what to do
geposted Fri 28 Aug 15 @ 1:43 am
Does VirtualDJ LE7 7.02 installs on your Mac ? or not installing at all ? or not running ?
FYI, older versions of VirtualDJ were using /Users/Username/Library/VirtualDJ and the newer ones use /Users/Username/Documents/VirtualDJ.
The error you are getting is because it cant find the LE skin. The 7.4.6 is an update and doesnot contain the LE skin.
So when the 7.4.6 is installed it will probably look into the 2nd folder and wont find the skin. If the 7.02 gets installed, copy the Gemini skin from the /Skins folder and paste it to the 2nd Skins folder.
If none of the above works, or cant follow my instructions, please contact with Support https://virtualdj.com/contact/ for further assistance.
geposted Fri 28 Aug 15 @ 3:32 am
