Hello, I had recently purchased a DDJ WeGo2 from Pioneer and I had connected it to my PC and I am running Virtual DJ LE. All the functions work fine on the controller, EXCEPT for the headphone cues. When I am connect headphones in, I am unable to hear the song that I want to cue up. I believe it may be something to do with my settings, but I cannot figure it out. Here are my current config settings:
Inputs - None
Output - Headphones - Master: Front output / Headphones: Rear output
Sound card - 4.1 Card - Speakers (PIONEER DDJ-WeGo2)
Please if anybody has a solution, it will be greatly appreciated!
Inputs - None
geposted Sun 30 Aug 15 @ 5:57 pm
not sure why u have the 4.1 sound card in your config at all ?
https://virtualdj.com/documents/Pioneer%20DDJ-WeGO2%20VirtualDJ%208%20Operation%20Guide.pdf
have a look on page 4
geposted Sun 30 Aug 15 @ 6:28 pm
You need to install the Pioneer WeGO ASIO drivers and use those instead of the WASAPI/WDM (4.1) ones.
So it should be ..
Sound card : ASIO and next to that you should see the option to select the Pioneer ASIO driver
So it should be ..
geposted Mon 31 Aug 15 @ 4:14 am
@ try2reach
it works best for me like this;
I have the asio drivers installed for both the WeGo & Wego2, but I could never get them to work.
pc, win 10 & 8.1
edit
oooops, sorry, just seen that you're an LE user, maybe that's different
hope you get it sorted out
ray
pc, win 10 & 8.1
edit
ray
geposted Mon 31 Aug 15 @ 12:55 pm
