Forum: VirtualDJ Skins
Topic: relay_play trouble in VDJ8
In VDJ7 my code for relay_play (=continuous playing of decks 1 and 2 alternately) worked fine. In VDJ8 it switches the playback between deck 1 and an unknown deck (that is used for the automix feature) and is completely out of my control (no play, pause, stop buttons, etc.).
As far as i could determine, there is no new or special code for this feature to work on VDJ8, but maybe I'm mistaken.
Does anyone know?
geposted Tue 01 Sep 15 @ 12:04 pm
Relay_Play works fine for me. I use it everyday. However, relay_play will play all LOADED decks using their sequence... Eg, 1,2,3,4,5,6,7,8,1,2,3,4,5,6,7,8 e.t.c
If only deck 1 & 2 are loaded then it will go 1,2,1,2,1,2. If deck 1,2 and a hidden deck 5 are loaded it will go 1,2,5,1,2,5,1,2,5 e.t.c.
So make sure that you unload any deck you don't wish to use when relay_play is active
Aha! That explains it. Didn't know that.
Again: interesting info, there!
Many thanks, Phantom.
