BUILD 2436 - BETA, the sync does not work on most of the music files that have a defined clear beat. When the sync buttons are pushed it will move the wave closer to the sync, but not all the way to a perfect beat sync. Not a big deal for me now but will need this feature when I do purchase the full VDJ 8 for my gigs.
I have read other sync error reports here also. I am more than confident that you will get it addressed as you always do take care of the problems reported. Your staff has the best Customer Support that I have ever seen for software help.
And I Thank You for your fast replies and help.
Jon J.
Jon J.
geposted Tue 01 Sep 15 @ 6:05 pm
There's definitely something going on with sync that I can't put my finger on. I've found that not using smart-play appears top get better results or hitting play on the "and beat" i.e. 1 and 2,3,4 seems to be smoother rather than the 1....
geposted Thu 03 Sep 15 @ 12:42 pm
Actually, just checking on the latest build... This is performing much better :-)
geposted Thu 03 Sep 15 @ 12:53 pm
The latest update has fixed the Sync problem. Much better!
Thank You Jon J.
Thank You Jon J.
geposted Fri 04 Sep 15 @ 5:13 am
