-Fix possible crash in skins using racks
-Fix crash when generating a video edit by drag&drop
-Fix possible audio encoder crash
-Fix green videos when dxva is enabled on nVidia
geposted Thu 03 Sep 15 @ 1:29 pm
Renaming Virtual folders with no content - Confirmed fixed in this build on Mac.
geposted Thu 03 Sep 15 @ 2:35 pm
crash 3x on VDJ-radio
geposted Thu 03 Sep 15 @ 4:04 pm
And the ns7 disaster continues.this build the sound skips and waves have intermittent pauses,previous build also had lots of crashes.in my ns7 original version experience,upgrades have failed or issues have compounded ever since 2325.
geposted Fri 04 Sep 15 @ 2:48 am
That means it's not a regression issue. Please open a topic in the bug report forum for troubleshooting your problem.
geposted Fri 04 Sep 15 @ 11:11 am
So far on this build: Stress tested it home and worked perfect. Did a gig and worked perfect! The only thing i noticed was that when i opened my pc it took some time for vdj8 to open. But after it opened one time if i closed it and reopen it, it would open in like 1 second. Maybe its a pc or windows thing but nothing major. I am seeing this one getting public. Good job guys!!!!
(Using Windows 7 64 bit i7 nvida graphic card, denon mk2 mc6000 Mp3 and mp4 files)
geposted Fri 04 Sep 15 @ 6:24 pm
.png)
The dxva issue is still happen. And I don't have nVidia gpu.
I'll leave my pc's specifications here:
System Information
Time of this report: 9/4/2015, 21:11:07
Machine name: KARAOKE-PC
Operating System: Windows 10 Home 64-bit (10.0, Build 10240) (10240.th1.150819-1946)
Language: Portuguese (Regional Setting: Portuguese)
System Manufacturer: Hewlett-Packard
System Model: HP Pavilion 11 x360 PC
BIOS: F.27
Processor: Intel(R) Celeron(R) CPU N2820 @ 2.13GHz (2 CPUs), ~2.1GHz
Memory: 4096MB RAM
Available OS Memory: 3984MB RAM
Page File: 1944MB used, 2742MB available
Windows Dir: C:\WINDOWS
DirectX Version: 11.2
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.10240.16384 64bit Unicode
Display Devices
Card name: Intel(R) HD Graphics
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0F31&SUBSYS_2209103C&REV_0C
Display Memory: 1792 MB
Dedicated Memory: 64 MB
Shared Memory: 1728 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: AUO315C
Native Mode: 1366 x 768(p) (60.070Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.4252 (English)
Driver Version: 10.18.10.4252
DDI Version: 11.2
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: Thread group
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 7/11/2015 00:49:34, 10948400 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4C71-11CF-1063-0302B1C2C735}
Vendor ID: 0x8086
Device ID: 0x0F31
SubSys ID: 0x2209103C
Revision ID: 0x000C
Driver Strong Name: oem43.inf:5f63e534a222b607:iVLV2M_w81:10.18.10.4252:pci\ven_8086&dev_0f31
Rank Of Driver: 00DA2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
geposted Fri 04 Sep 15 @ 8:15 pm
Is this happening with every video you tried? (The video on the right deck seems fine?)
If not, is it possible to share one of the videos that gives you a green screen?
geposted Sat 05 Sep 15 @ 12:19 pm
Tag editor. .. modification tag with using button when everything is in brackets change to Remix field and field Title is clean ( only title ) example : Artist - Title ( Remix)
not work.
Public version is Ready .
sorry for my english
not work.
geposted Sat 05 Sep 15 @ 1:32 pm
It's happening only with the karaokes from the same producer
geposted Sun 06 Sep 15 @ 12:55 am
in this vercion, cue stops responding for a short time, with aero pioneer ...
geposted Sun 06 Sep 15 @ 2:37 am
Ok, could you put one on dropbox or so and send me the link? Thanks
geposted Sun 06 Sep 15 @ 7:10 am
