I read somewhere (but I can't remember where that was, I think it was here on the forum), that VDJ8 has random video transitions built-in, so that the SBDJ plugin is not needed anymore. Is this true? If so, how do I activate that feature? It isn't anywhere in the (advanced) settings.
geposted Thu 03 Sep 15 @ 4:25 pm
Yes, look in settings..
geposted Thu 03 Sep 15 @ 4:27 pm
OMG... I must be going loco (or overworked...)
I looked but nothing came up (search function), and now I tried again at immediately the option came up. Sorry.
And thanks!
And thanks!
geposted Thu 03 Sep 15 @ 4:51 pm
No worries, happens to me too
Would be nice to have a way to select the transitions to be used like the plugin did. Hate manually moving files, but it does work.
geposted Thu 03 Sep 15 @ 10:00 pm
I see...
I only have the transitions I want in the folder, so that should be OK.
geposted Thu 03 Sep 15 @ 10:59 pm
You can always just move them using the effect selector into an 'Ignore' folder :)
geposted Fri 04 Sep 15 @ 11:14 am
I will have a look at that. Thanks!
geposted Fri 04 Sep 15 @ 3:58 pm
