-Auto_crossfade and video_transition can move to a specific location
-Prelisten start position stored in config
-Fix crash on endless recursion in browser
-Fix deleting custom mapper
-Fix loop_exit jumping to bad slipmode position when no loop was set and looproll mode was on
-Fix mac crash when loading or analyzing a file with corrupt length tag
-Fix mac showing certain notifications twice
-Fix Cube and Satellite transition position off
geposted Sun 06 Sep 15 @ 6:33 pm
rocking! thanks DJdad / team for the fast fix! testing today
just tested: bug still there: :( slip grid "cursor" still doesn't reset to zero when loading a new track, but only if scratched first. For extensive explanation:
https://virtualdj.com/forums/203559/VirtualDJ_8_bug-report_Forum/SLIP_MODE_bug_in_combination_with_Loop_exit_command__.html
please note: This bug is there with loop_roll enabled or not! has nothing to doo with looproll mode. I have it off and it's there.
geposted Mon 07 Sep 15 @ 10:06 am
For me it´s new! MAC
How i can change the "ShopDemoMode" to -> NO
Stop IT!
Stop IT!
geposted Mon 07 Sep 15 @ 9:50 pm
If you accidentally set this setting to yes you have two options:
1) Kill VirtualDj by using Task Manager and use a text editor to open settings.xml file and edit this setting back to "No" or
2) Kill VirtualDj by using Task Manager and delete your "settings.xml" file from your system.
Unfortunately there's no other way to stop "ShopDemoMode" and that's not a bug, it's by design. When in "ShopDemoMode" VirtualDj cannot be closed and all it's settings will reset automatically every 5 minutes
geposted Mon 07 Sep 15 @ 10:07 pm
Ever same problem with Tag Editor . Field Remix not work with button Get Artist/Title from Filename and (Remix) to field Remix
geposted Mon 07 Sep 15 @ 10:16 pm
Thanks, why don´t implements an admin password to reset this mode?
geposted Tue 08 Sep 15 @ 6:08 am
Shop Mode is a feature for promotion in shows, customized fairs or shops.
This feature is in advanced settings on purpose.
Unfortunatley it is not a regression bug for it is there since the very first official build.
Feel free to continue in the General Discussion Thread if you wish.
geposted Tue 08 Sep 15 @ 1:38 pm
someone show me an VDJscript example ?
Thnx
geposted Wed 09 Sep 15 @ 3:39 pm
sorry to repeat but had no reply.. this is not fixed see above. comment anyone?
geposted Wed 09 Sep 15 @ 4:14 pm
The Karaoke crash i was experiencing with a prior build is back with this one. I had to go back to 2438 to keep my show going. and yes, DXVA is OFF.
HP Envy 17
Win 10
Nvidea Video Card
HP Envy 17
Win 10
Nvidea Video Card
geposted Thu 10 Sep 15 @ 2:41 am
Renamed folders are sorted to the end of folderlist and this persists after reopen VDJ.
It is wrong sortet in "This PC Subfolders", Desktop Libraries and Favorites Folders.
I saw this behavior never before in VDJ
geposted Thu 10 Sep 15 @ 4:38 am
Proart that isn't a regression bug.
geposted Thu 10 Sep 15 @ 8:20 am
And you can fix it using right-click on the parent folder.
geposted Thu 10 Sep 15 @ 8:51 am
When I start up VDJ 8 I have to go in to Audio setting and redirect MXR19 audio channel on each startup . Im using Channels 2 and 3 on the mixer VD8 recognizes the audio as Deck 1 Channel 1 and 2 Deck 2 channel 3 and 4 . Deck 2 is dead until I change that to channel 1 and 2 as well.
geposted Thu 10 Sep 15 @ 3:40 pm
You're right Adion rightclick on parent folder has an option to reset the sortorder.
But on top of my favorite Folders this option is not available. So i thought this is a regession bug.
Thank you very much.
geposted Thu 10 Sep 15 @ 3:45 pm
Most likely this is not a regression bug, since nothing has been changed in audio or Controllers.
Make sure the AA ASIO drivers are installed or re-install them if you have been using those already.
Since it seems that you are using Windows 10, there may be an issue of incompatibility with the drivers.
Please open a new topic in the Ver8 Bugs forum (not here) and provide further details in case the above doesnt resolve your issue.
geposted Thu 10 Sep 15 @ 5:16 pm
experiences with this version, touching knobs headphone mix and volume, the decks are slowed, then goes soft, also flash on the skin, lower master volume, and small cuts on the issues were ...
geposted Fri 11 Sep 15 @ 7:39 am
Make sure you are using the right mode:
https://virtualdj.com/documents/American%20Audio%2019MXR%20-%20VirtualDJ%208%20Operation%20Guide.pdf
geposted Fri 11 Sep 15 @ 9:52 am
Cheers everyone for your help. :)
geposted Fri 11 Sep 15 @ 10:26 am
Just updated to this version (12.30pm uk time). First thing to happen was the fan on my laptop suddenly working overtime to get rid of the scary heat it was chucking out, I went back to the previous version and the temperature went back to its normal warm state. I left it to do a 10 minute automix with no rise in temperature and the fan was quiet, I then updated to the current version again (2441) and within 10 seconds the fan kicked in hard blowing out hot hot air. This is using the default skin or FRUiTs skin.
Skin FPS is set at 0 (not 60) as it seems smoother to me. No Anti Virus is installed or any other kind of scanny program. I've restarted the laptop 3 times just to make sure and gone back and forth to this and the previous version with the same results.
Dell Inspiron N7110 ,64bit ,16GB Ram, 17.3" Screen ,Windows 7, all drivers current, Music is stored on external HDD but built into where the CD/DVD drive bay was
geposted Fri 11 Sep 15 @ 12:18 pm
