I've got 'get beta builds' disabled on the PC version yet when asked to 'use new version' I'm getting the Beta build instead of the latest Public build.
Also, I've tried to download the zip for Public build 2438 and can only get the full install which will not install over build 2441.
I don't want to use the Beta builds only the Public builds. Thanks.
geposted Mon 07 Sep 15 @ 5:17 pm
Check 'My Account' on the forum, possibly get beta builds is enabled there.
geposted Mon 07 Sep 15 @ 5:19 pm
Is it also disabled on your account page?
[one second later] Haha, snap!
Yep, was set in 'My Account', although after disabling it then installing build 2438, I was asked if I wanted to update to Beta Build 2441.
Check for updates was set, but, get Beta builds was disabled.
geposted Mon 07 Sep 15 @ 10:07 pm
It is possible that the update was already downloaded to your virtualdj folder. (Documents\VirtualDJ\Cache)
geposted Tue 08 Sep 15 @ 5:33 am
Ah, that would explain it. I should imagine that over time this won't happen anymore.
Thanks for your input Adion.
geposted Tue 08 Sep 15 @ 7:41 am
