Forum: Old versions
Topic: Keyboard Shortcut for Sound
Hi!
I am a student new to VirtualDJ and I love changing the sound level of the music. The item I use to change the sound is a 'slide' that is located below the Gain knob and next to the High, Mid, Low and Filter knobs. It is located, obviously, on the Mixer tab. I was wondering if there was a keyboard shortcut to raise and lower the sound using this slide. Sorry for not using technical terms, I am an amateur DJ! Thank you in advance, Enfeu.
geposted Tue 08 Sep 15 @ 1:36 am
these sliders are know as up faders or gate faders,
there isn't a default mapping for these sliders so you'll have to make on yourself.
These are the scripts you'll need
deck 1 level +2%
deck 1 level -2%
deck 2 level +2%
deck 2 level -2%
OK thank you very much for the answer! How do I do this mapping though?
Go into mapping
Click the key learn box (1)
Enter a key
Pick the entered Key (2)
Add the action/script (3)
Im on mac but this script not working!!!!!
What im doing wrong? Help please!!!!!!
No clue?
