Forum: Old versions
Topic: Denon MC3000
When a song is loaded in player A (1) and you raise the volume slider the song starts playing automatically. This only happens in Player A (1), none of the other players do this. This just started happening and I have not changed any settings.
I have changed skins thinking that this might solve the problem but it happens in all of the skins I have.
Can someone guide in the direction to stop this from happening. I do not want the song to start playing when the volume slider is raised.
geposted Wed 09 Sep 15 @ 11:47 am
You have enabled Fader Start on deck 1 (left).
Map a custom button on the default skin or a keyboard shortcut as ..
deck 1 fader_start
Press the button once to disable.
Make sure the fader is OK now.
Delete the shortcut, just in case you enable it by accident.
