Forum: Old versions
Topic: Multiple PCs?
Can I install VDJ single controller version on multiple PCs? It seems I have a lot that crash and I need to reinstall my software periodically. Or it would be nice to load it on another PC for a backup. Thanks for any information!
geposted Wed 09 Sep 15 @ 5:29 pm
The Eula says;
v7 2 machines at any one time but you can install/reinstall as often as you like so long as you only have 2 machines active.
v8 You can install on as many machines as you like as login takes care of it.
Thanks...I knew I should have read those things :)
