Forum: Old versions
Topic: Installation Issues-American Audio VMS2
I recently just purchased the American Audio VMS2. I already had Virtual Dj Pro on my computer (computer meets all requirements). I went to install drivers and installed them. Virtual DJ is not recognizing controller at all. What am I doing wrong? Do I need to do a uninstall on the current version on Virtual Dj 8? and reinstall it to get it to work? thanks
geposted Fri 11 Sep 15 @ 1:28 pm
No reinstallation required.
Do you "see" the controller if you turn it on and open the AA ASIO driver control panel?
Oh and btw. what operating system do you use?
I seen the controller once and currently I don't see it. I am using windows vista. Once I see it whats the next step?
Update to win 7.
I really can't recommend using vista.
Especially not with the vms devices.
Had to use a vista laptop once with the vms 4.
It was just impossible to use. Only crackling sound and stuff. No matter what latency i used
