Using VDJ 8 Skin i would like to add two limiter lights to position shown. Original is the top, bottom how i would like it. I know it is the 2 decks xml file but not sure how i can add in this?
geposted Fri 11 Sep 15 @ 10:35 pm
Well have it how i want it, not 100% sure my xml coding is in correct place though
geposted Fri 11 Sep 15 @ 11:03 pm
Send to me the Skin I will make it work for you, and I will return it to you within a few hours. It is an easy fix for me.
I will send to you a private message with my contact info.
Please also check with the skin creator for permission to alter his skin.
Jon J.
Jon J.
geposted Sun 13 Sep 15 @ 1:29 pm
Thanks, it is the default skin that comes with vdj 8
geposted Sun 13 Sep 15 @ 1:42 pm
I have looked at that skin and I do not have the skin tool to add those Over Peak Indicators for you. This skin is made with a very different process. Contact the Skin crator and maybe he can do what you want.
Sorry I can not help on this one.
Jon J.
Jon J.
geposted Sun 13 Sep 15 @ 8:48 pm
Its ok, think i have managed to do it myself thanks.
geposted Sun 13 Sep 15 @ 9:01 pm
