Forum: Old versions
Topic: BPM editor doesn't match waveform viewer
I am confused about the track analysis function.
When I see the track in the waveform viewer the beats are picked obviously incorrectly. When I go into the BPM editor to fix this they are correct.
If I play the track while in the editor, to see where it is picking the beat from, the viewer and the editor do not seem synchronised. Is this something I am doing incorrectly?
The two images show the disparity between the two.
http://i.imgur.com/bd62GT2.png
http://i.imgur.com/bYH06Rw.png
geposted Sat 12 Sep 15 @ 10:35 pm
might want to make sure u are running the latest version i think there was a build that this was happening
if u go by the boxes in the viewer u will be good though
