Given the updates it is still having
https://virtualdj.com/wiki/VirtualDJv8.0builds.html
How can we check in VDJ8 when these updates get released, i only noticed by the version number on download page?
geposted Sun 13 Sep 15 @ 10:49 pm
use the public builds and all will be fine skip the betas if u are worried
geposted Sun 13 Sep 15 @ 11:38 pm
So the b in VirtualDJ 8.0 b2441 PC means it is beta?
Is there not an update check manually done in 8 as it was in 7?
geposted Sun 13 Sep 15 @ 11:56 pm
b=build
you can always look here for PUBLIC release and beta releases
https://virtualdj.com/forums/76/Beta_Builds_Regression_Bugs.html
geposted Mon 14 Sep 15 @ 12:57 am
Thank you.
geposted Mon 14 Sep 15 @ 6:50 am
Look into your profile here and see if the "get beta builds" checkbox is check.
Also, check the setting "getBetaBuilds" in VDJ. Set both to "no" (uncheck).
If VDJ now displays an update message it is always the public version.
geposted Mon 14 Sep 15 @ 8:39 am
