Hello. Using the G2V, and Virtual DJ LE, why is that when I load a song in one deck, there is a slight skip in the audio, it doesn't appear in the final recording, but it does appear live during my mix. When I load a song into the deck a slight moment of silence or static will occur. I have tried to lower all knobs to 0 before I load the track in but it still makes that skipping sound through my speakers. Any ideas?
geposted Fri 18 Sep 15 @ 7:59 pm
If you are using the Gemini ASIO (in Windows), try to set the latency to a higher value.
You will also need to make sure your computer is well optimized, so take a look here.. https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
geposted Fri 18 Sep 15 @ 9:14 pm
Awesome thank you I will check it out
geposted Fri 18 Sep 15 @ 9:46 pm
