Forum: Addons
Addons comments
Topic: Pioneer XDJ-RX By Zaik
geposted Sat 19 Sep 15 @ 12:45 am
I downloaded your skin and would like to know what dpl mod is suppose to do
geposted Mon 26 Oct 15 @ 6:15 am
Nice Skin but Resolution is wrong for VDJ 8. I Can not resize it to fit properly. Tried 1440x900 and 1600x1080 with no luck. it is stretched and not in screen aspect.
geposted Sat 07 Nov 15 @ 12:22 am
A melhor skin para virtual dj na minha opinião! recursos ultra avançados que permitem as mais variadas formas de mixar! todos os recursos de uma autêntica controladora Pioneer!
geposted Mon 16 Nov 15 @ 2:30 am
Would be nice if the rhythm window was longer and the default vdj wave was added. Would love some hot cue buttons as well. Those are the only things that's stopping this from being my main skin
geposted Sun 20 Dec 15 @ 9:24 am
What res & ratio is your screen?
The skin (as stated on the download page) is 1600x900 which is exactly the same 16:9 ratio as 1920x1080 (VDJ 8 default size), so it should scale up to any 16:9 ratio screen without distorting.
geposted Sun 20 Dec 15 @ 5:26 pm
Hi I need to ask if this controller plays mp4 or videos while connected to a computer I am guessing that with usb no videos playable is possible but via usb(computer ) it is . Its quite confussion the description of the pioneer page thank you very much for your answer.
geposted Tue 21 Jun 16 @ 10:41 pm
ema mizHome userMember since 2012
Hi, how do I remove this mask? I want to change it but I do not have menu options
geposted Wed 25 Jan 17 @ 8:42 pm
its god skin
geposted Mon 06 Feb 17 @ 4:35 am
even better if was in different skin colors like silver
geposted Sat 16 Dec 17 @ 2:08 pm
machozsHome userMember since 2019
Nice skin! Best for me! But 1920x1200 pls!
geposted Wed 16 Jan 19 @ 2:30 pm
How do I use microphone input with this skin? The button that says "Mic" are not functional.
geposted Wed 13 Feb 19 @ 6:03 pm
I would still like to know how to turn on the mic using this skin. That is the only thing I cannot seem to figure out.
geposted Wed 08 May 19 @ 5:00 am
locodogPRO InfinityModeratorMember since 2013
Do you have a microphone input configured?
geposted Wed 08 May 19 @ 5:09 am
The "mic on" button is not functional for this skin. So unless there is another way to turn on the mic with this skin I do not know. That and also I am not sure how to use VirtualDJ's visualizer on this skin either. Cause when I click the "video" button is just says "DVD Video" and right click does not bring up options to pick a visualizer setting.
geposted Fri 14 Jun 19 @ 3:29 am
Dgb1712Home userMember since 2019
Nao consegui fazer o dowload
geposted Mon 02 Dec 19 @ 8:40 pm
