-Fix getRemixFromFilename
-Fix crash seeking some cdg files
-Fix memory leak when reloading skin
-Faster response of automix_skip
-Fix paths on database stored incorrectly for files on other drives when the drives are not writeable
-Fix database not set to not writable when permissions don't allow it
-Fix browser file list for vdjRemote in sidelist view
geposted Sat 19 Sep 15 @ 11:44 pm
Awesome This is a great work
geposted Sun 20 Sep 15 @ 3:42 pm
Looking forward to this release. Keep up the good work.
geposted Sun 20 Sep 15 @ 8:02 pm
There was a few weeks of instability, however it looks like things are getting back on track.
Very pleased lately!
geposted Sun 20 Sep 15 @ 11:37 pm
When load video on deck, in preview have old picture previous video .I After press play button or cue it is correct.
Sometimes changes the set speed (but only a little)
geposted Sat 26 Sep 15 @ 9:55 am
This build is running perfectly (unlike build 2441 - 2454 with the crazy heat issue and other small things), used it last night at the club I play in with absolutely no issues, samples, effects, loops all were performing as they should - Thanks Atomix
geposted Sat 26 Sep 15 @ 3:06 pm
sometimes vdj crash when loading video
Last build used: 2465
crash 839502 with build 2465
crash 835205 with build 2465
crash 835181 with build 2465
geposted Sat 26 Sep 15 @ 6:30 pm
I'm being asked to install Apple Bonjour to use the remote app, which I've used for months and Bonjour is installed.
Forget it, it was switched off on the PC for some reason unknown
geposted Sat 26 Sep 15 @ 6:42 pm
Have an issue that just started with this build, last build I used was last public build. My issue seems to be a Video freeze towards the end of playing video if audio file is to be played next with Milkdrop enabled as a play with audio file.. I am going to reinstall previous version and see if it does it tonight. Sad I really liked this version due to the remote app fix..
geposted Sat 26 Sep 15 @ 10:17 pm
Im seeing this video freeze too, after about 4 mins happening on any video file type..
geposted Sun 27 Sep 15 @ 2:18 am
Track cleaner caused restart with no warning. Same happens when Censoring
geposted Mon 28 Sep 15 @ 7:02 am
There are some crash reports received from the latest build. The development team will take a look.
geposted Mon 28 Sep 15 @ 7:31 am
had some sync issues and forward / backward search beatsync issues with build 2436 that I didnt use to have before.
not using the new one yet. so this refers to 2436
geposted Thu 01 Oct 15 @ 8:44 am
So it is not a regression bug since there have been numerous releases since then, including a public release.
For normal bug reports please use the bug report forum.
For a bug that is new since the last public release - in this case 2441 - then this is the appropriate forum to use.
geposted Thu 01 Oct 15 @ 10:56 am
Problem reading mpg and bob format (mp2 video codec) black image.
geposted Fri 02 Oct 15 @ 3:36 am
Me too. Not loading any VOB video, olnly playing audio. MP4 video works fine. Switched back to last public version available for today's gig.
geposted Fri 02 Oct 15 @ 11:16 am
Possible to share one of these that don't play?
All the mpg and vob I have here play fine...
geposted Fri 02 Oct 15 @ 11:55 am
Problem with me too but playing wmv files
geposted Fri 02 Oct 15 @ 12:19 pm
I have troubles with all Vob and MPG :(, I could fix with 2438
Nvidia GeForce GT 750, MAC Retina.
geposted Fri 02 Oct 15 @ 9:22 pm
ok on 2465 now
-Fix elastique glitch on first pitch change this issue is back
that is if it means::: when pressing sync it does change the BPM number, but the audio doesnt follow in the right tempo... you have to try it like 3 or 4 times before the tempo is actually set right
geposted Sun 04 Oct 15 @ 8:38 am
