Topic: Serious problem with "Move to ..."
hi guys, I don't know it happened, but when use the "move to" with 5 mp4 files to "example folder" took the 6115 mp4 files that I have on my hard drive and move to folder "example folder".
This is a very serious problem for me, considering how long I'll have to invest in order to return to file by file in appropriate folders.
Use the version for Mac 2391.1060
rgds!
geposted Sun 20 Sep 15 @ 12:38 am
Sorry i don't understand you....
You mean, moving 5 files does work, but moving 6000 files doesn't?
Oh, but first, please update your version. 2391 is an old build, there are newer ones available.
Latest beta is version 2454.
no, I mean that by moving 5 files, moved 6000 files.
and about update, I always check the "Beta Builds Regression Bugs" and I see each discontent or problems other users, and this beta worked fine (so far) for me.
thk PachN
you must realize to get fixes that get implemented you will need to get the newer builds ... also this issue may be fixed already in the newer builds.. i doubt it will be fixed unless you test the latest build and find the issue remains.
