To include Total Time of tracks in side list ( same as in automix)
geposted Mon 21 Sep 15 @ 9:52 am
Temporary solution:
This will switch everything from automix and sidelist.
If you want i could make you a script for a button that you can hold down and it will switch lists and views and when you release it goes back to the previous state.
Regards,
Daniel
switch_sidelist_playlist
Regards,
Daniel
geposted Tue 22 Sep 15 @ 2:50 pm
thanks, that should do the trick, easy to forget whats what though i guess, but maybe just use automix as my side list although i cant get keyboard shortcuts for loading and removing to automix, but can side list
Be better to have it there in the program really,
geposted Tue 22 Sep 15 @ 3:04 pm
that, ofcourse, is the easiest solution =D
geposted Tue 22 Sep 15 @ 3:06 pm
