Hi there.
I have an issue that i can't configure mono whatsoever using the VDJ Pro 7.4.1.. I have everything set-up under config:
Input - NONE
Output - External Mixer
Sound Card: MONO SEPARATED (using headphones)
Problem is i still get stereo sound with my headphones if i insert music to only the left deck and pull the slider to the left side it's still stereo. How do i achieve that the left-deck only plays sound on the left side of my headphone and the right deck on the right side?
Thanks.
Input - NONE
Thanks.
geposted Mon 21 Sep 15 @ 5:16 pm
what do you want exactly to setup ?
what are your hardware specs ?
Do you want to have:
1st Mono Channel on Master out ?
2nd Monochannel on Headphone ?
geposted Tue 22 Sep 15 @ 9:17 am
All i'd want to achieve is basically the left deck playing music in the left-side of my headphones at the same time the right-deck is playing music in the right-side of my headphones.. is that possible using VDJ7? it's an USB headset, i do have a 7.1 SoundBlaster soundcard.. i'm not really at home with this software so i don't know what i need and such.
Also, it kind of works, but i can still hear the left deck on the right side just on a lower volume.
geposted Tue 22 Sep 15 @ 6:00 pm
Well really you should be using v7.4.6, show us a picture of your audio config.
geposted Tue 22 Sep 15 @ 8:14 pm
USB Headset is not really useful for this kind of config. . Perhaps that is why you still have the lower level...
geposted Wed 23 Sep 15 @ 4:11 pm
