VDJ Pro 7 user here.
Using a Behringer controller pad CMD-DC1.
I'm trying to learn XML commands as I've been programming this thing, but....
Does anyone know if it's possible to map a variable knob on a MIDI device to the Pitch Up/Down feature in VDJ.
I'm aware of using hard buttons to "up by 2%", "down by 5%", etc, but don't know if it can be assigned to a rotary knob...
Something like "12 o'clock" being normal, and swing either way for down/up.
Thanks all,
Doug
Thanks all,
Doug
geposted Mon 21 Sep 15 @ 10:16 pm
Have you tried to assign this action only
Pitch
Pitch
geposted Tue 22 Sep 15 @ 2:05 pm
What you can't:
Have a knob that sets the velocity of the slider-change.
What you can:
Map a non-infinite knob to the pitch slider (from 0% to 100% by default ofcourse).
12 o'clock would be +0.0 pitch.
Script:
If you want to map an endless encoder (like a browse knob) that has steps to control the pitch,
you could also use
but you probably want to manually change the size of the steps.
To do this use this code:
Replace X with the percentage value that you want to move each step, for example:
That's it!
Also no, it's not really a dumb question since vdjscript is a lot different than other languages and it can be quite confusing some time.
Regards,
Daniel
What you can:
Script:
pitch
you could also use
pitch
param_bigger 0 ? pitch +X : pitch -X
param_bigger 0 ? pitch +1.0% : pitch -1.0%
That's it!
Regards,
Daniel
geposted Tue 22 Sep 15 @ 2:10 pm
BOTH solutions work perfectly!
Thanks guys!
Thanks guys!
geposted Tue 22 Sep 15 @ 3:20 pm
